Quote from: samm1129 on August 18, 2017, 01:24:43 AM
is there a way to add online multi-pool service like Prohashing.com it's just like zpool and has API's of profitability.
Quote from: patrike on August 17, 2017, 11:41:32 PM
If they have single coin pools, where the coin is listed on WhatToMine, it will work with the profit switcher. If they have multi-coin switching pools, then it will not work until Awesome Miner includes support for the Prohashing API. Prohashing has some strange design of how to pass worker names to their pool, so I was hoping they would fix this flaw first.
Why Awesome Miner does not support PH
Re: Why Awesome Miner does not support PH
Yes I also contacted them regarding this and got the same response. I would imagine it's pretty low on the priority list to try and get integration with AM working better though.
its not very awesome then..
It's a great piece of software, i've been using it forever, sad to see that PH isn't utilizing it and free referrals it provides to the services.
