I've just spent the last 30 minutes PUNISHING bot users on Cryptsy. You should try it out. It is hilarious
I used like 50 cents worth of Dash to make bots sell off into huge cheap buy walls
If you detect a bot, which is easy...........they will constantly go 1 sat lower than your sell price. When you see this.....PONCE!!! Set a small sell amount one sat higher than the current buy....the bot will sell into the buy. When you see the bot cancel an offer, quickly cancel yours so you don't accidentally sell into a buy. Bot will sell into the buy, so just rinse and repeat until you get the price down to a nice cheap buy wall, sell at one sat higher again, and POOF!!! the bot sells into the cheap buy and is gone.
If you are placing sells and cancelling quickly enough, you will not sell anything.....then can safely place your sell at a decent price........until the bot gets reloaded.......then you know what to do
