Hello,
Is there a method to dual mine ETH and ZIL with Prohashing? I looked into pools, like sharedpool and rustpool, which out luck getting it to work. Anyone try this before?
Dual Mining ZIL and ETH
The Mineable Coin Announcement forum is for discussing new mineable coins and cryptocurrency technologies. One topic per coin, please. Feel free to submit a support ticket for inclusion in the "Coin communities" forum if your coin would like a centralized place for discussion.
Announcements for pre-mined token sales are prohibited on this site. Please restrict posts to new mineable or stakeable coins only.
- Contact:
Re: Dual Mining ZIL and ETH
Unfortunately, ZIL isn't currently supported by Prohashing and uses a custom API, so it wouldn't be simple or quick to add it.Heyabbotts wrote: ↑Thu Sep 23, 2021 9:52 am Hello,
thank you for replying and letting me know
This can be done using zilswitcher. You can only use it with shardpool for zil but can run any coin/pool you want for secondary not just eth. Ive done it with erg and rvn.
https://bitcointalk.org/index.php?topic=5153753.0
